sonix
Well-Known Member
I am in the process of building my own speakers and need advice on a nice modern cross over for my Mid Horn and Tweeter Horn speakers.
I have decided to not use the woofer from this set because it is only 40w Max and is 100DB efficient which produces very little base. Instead I am using 12" woofers from Infinity 1001A. The woofers are wired direct with no x-overs in the signal path, just the way they were in the Infinity 1001A boxes.
In my opinion the mid horn sounds to bright more like tweeter especially when I turn the subs off. (These are Bi-amped) So I need your help on a good cross over desing for the mid horn and tweeter. Maybe I can purchase one that is already put together without having to build one.:scratch2: I don't really like the attenuator pots in the original cross over boxes. All the caps are original in the network as far as I can tell.
I have included all the info on the horns and network in the links below. So for those of you with more experience, please look at the specs and give your suggestion for a better X-over network.
From my little experience I noticed that the simpler the design the better the sound.
http://audio-database.com/PIONEER-EXCLUSIVE/unit/dn-31-e.html
(X-over)
http://audio-database.com/PIONEER-EXCLUSIVE/unit/pw-30f-e.html (Woofer)
http://audio-database.com/PIONEER-EXCLUSIVE/unit/pm-500-e.html
(Mid Horn)
http://audio-database.com/PIONEER-EXCLUSIVE/unit/pt-7-e.html
(Tweeter Horn)
Looking forward to your suggestions:thmbsp:
(X-over)
(Mid Horn)
(Tweeter Horn)
