Class A generally exhibits the least distortion but is the least efficient (and therefore they run hot!). Class B exhibits higher (but still pretty low) distortion but runs pretty efficiently (thus producing a lot of power while remaining relatively cool). Class A/B runs in class A for the first watt or two or three (or maybe even 10) then switches over to class B operation as more power is needed to drive the required signal output. Most (not all) modern Solid State amps are Class A/B amps. The execution of the class A/B amp has been improved over the years and many excellent sounding audiophile grade amps are A/B switching amps. The further into Class A an amp is biased - the longer it remains in class A operation and the hotter it tends to run. A 20 to 50 watt amp that runs in pure class A requires an amp the size of a 200 watt to 500 watt class A/B amp and it will generate a lot of heat. There are also other Classes of Operation that I'm not completely aware of what they "do" electronically. There are some Class H and Class G amps but I'm not sure how or if they differ from Class A/B operation. Class D is a newer amplifier type that is highly efficient and can produce large amounts of power from fairly small - lightweight amps. These are getting better as designers and builders get better at implementing this topology. Most Pro Sound amps are now Class D as they greatly reduce the weight of PA/Concert systems that have to be "portable" to one extent or another. Class D amps allow mfg'rs to build dsp crossovers / eq's, etc. and the amplifiers needed to biamp or triamp (or even quad amp) a speaker right into the speaker cabinet - using an internal "plate amp" type arrangement (thus doing away with racks and racks of amplifiers altogether). Many of the long hanging columns of line array speakers you see at concert venues are amplified using these DSP modules and Class D amps built right into the speakers. Many also use external dSP processing and amplifiers - all depending the preferences of the designers and sound contractors involved. That's a quick and dirty overview. There are people here on AK that can provide far more information and better detail. - and I hope they will chime in to correct any errors or omissions that I have likely made.Can you tell me more about Class A-B amps, versus Class-A or Class-B’s? Is one better than the other?
). I remember when Sidney Harman sold Harman/Kardon to Beatrice food company for $100 million in 1977 (peanuts today). To a "food" company. This, i.e. the late '70's and certainly the stake in the heart of 1980 going forward, is when you really started seeing this and where so much more started going wrong that clearly led to where we are today but that becomes another topic entirely. I can't think of any company that has bought a once illustrious audio company and having any kind of reputation for making it better. I don't believe there are any examples; it just doesn't work that way, and I must resist the temptation to continue to digress.
