I'm sending my shipping address now?From my PSA-2XH:
said I was sending an address, no mention of money.Not for sale. Only for visualization.
The Crown D-150A is one of my favorite amps. If I remember correctly, it's the one that was still made in the USA. I read that the series 2 is manufactured in China and isn't as versatile as the 150A. I don't think it can be run in mono mode (could be wrong). I should have bought more of the D-150A on the used market when they were still plentiful and cheap. Now I see a lot of Series 2 or bombed out 150A units. 7 of the D-150A in mono config would make for a brutal HT setup.
Manny, I was a Crown authorized warranty in the early nineties, and I can confirm, at least all the series II amplifiers, both the 150, and the 300`s that came across my bench, and the ones that I own were all made in Elkhart Indiana USA., so this is the first that I`ve heard of them(D-150 II`s being manufactured off shore !!
Not saying it`s impossible, during the 2000`s, when HK started crapping up most of the audio electronics companies they purchased, as I had retired from public audio equipment repair by 2002 and was unconcerned about where they were manufactured, as I had collected enough of their earlier amps, plus multiple spares to carry me for the rest of my life, if need be..
I have owned, and still own and use their amps, from a D-60(excellent SS headphone amp) to the 2 PSA-II`s I`m loaning my B-I-L, and have all been solid performers for decades in daily use with very minimum maintenance after going through them on the bench and replacing the handful of usual suspects that time and rock bands abuse had delivered, since all my purchased Crown amplifiers, but a pair of 1997 2 Power Tech 3`s were purchased used..
I've never seen a D75A made in China, though I read the same Rockwell review you may have which makes it true because it was on the Internet! Cut rate really means it loses the binding posts and goes with barrier strip screw connections for speakers. I have several D75A (as well as D45s) but if I need to bridge any Crown amps, I just go up the next size, so lack of external mono switching never bothered me. Nice amps.
Gosh darn it... you are right. I was thinking about the D-75 vs the D75A The A version was considered a cut-rate (or as marketing would say....more cost efficient) version of the original D-75 which was easily bridgeable to mono (vs the A version which had to be opened up) and was (I think) close to or a little over 100 watts in mono configuration plus balanced inputs! I "grew up" listening to them in pretty much every rack I worked with and I still keep an eye out for them.
What a brain fart!
That`s ok Manny, living in Miami FL. can have that effect on the mind over time !!
I completely understand Sir.
Crown was a very, very good audio company in it`s day IMHO/E..![]()
Has anyone ever hooked one of these up to a home stereo speaker?
Is Crown no longer making good/reliable products?
Let's just say you wouldn't be the first to integrate modern Crown amps into a state-of-the-art system:
http://www.jblpro.com/china/product.../m2-series/m2-system-integration#.XFZWsBlKgWo
1502 in BT if you hurry.I think I will try out one of these especially at these prices and see what the modern Crown amps are sounding like.
