Crown IC 150a is this normal
Jasaab
Member
Just recapped a Crown IC 150a. I know this preamp gets bad press but the recap and new op amps ( BB OPA627) make this a nice unit. However, something strange occurs. The right channel comes on first then the left channel comes on about 6 secs later?. Seems like a delay on powering up left channel. After the 6 seconds all is well.
Check to make sure the muting relay isn't staying open (the contacts aren't closing and making continuity when the preamp is turned off), on the channel that comes up first.
That relay is normally closed- when the preamp comes on, the control IC will turn on that relay (opening the contacts) after a delay. This "un-shorts" the audio signal, allowing sound to come through.
If the relay contacts aren't working- corroded, broken, etc- it won't mute on the affected channel.
Regards,
Gordon.
I see by the schematics this is a reed relay looks to be 24 volts. 5 ohms? I see alot of reed relays with 24 volts but 5 ohms. How critical is that (5 ohms) if I am to replace?
jim
