Hi folks,
I'm new to the forum and might have missed something on this in my searches, in spite of trying. Hoping someone can nudge me in the right direction here
I found two D150a power amps and an IC150a, still in original boxes and in great shape, having been stored since the 80's sometime. After cleaning switches and pots to clear up some popping and scratching, there remains a rhythmic popping sound when set to phono 2 on the left channel. When using phono 1, there is no such problem until the TT is in auto-return, then the same characteristic rhythmic popping sound is heard, only on the left channel. I've tested with another pre-amp and the two D150a's and don't get the problem, so I'm thinking that there is something in the integrated crown phono pre-amp. - Any suggestions?
I'd like to fix the IC150a phono if that's the problem, but I suppose I can also use a separate phono pre-amp with the D150a's. Any suggestions on a phono pre-amp, or perhaps replacing the phono pre-amp in the IC150a?
Thanks for any guidance
