Crown psa2 double restoration Italy
PSA2 ITALY
Hello everyone I'm busy to renovate two Crown PSA2 here in Italy...
I'm dreaming on them since 1989..
At that time they were to expencive for me..
5.000000 lire ( 2500 dollars).
I need to find the correct screws kit for the external panels of both .
Can you please help me to find it?
Regards
Which external screws?
The ones for the rack mounting? Thumbscrews
The ones holding the rack ears to the chassis? Allen socket screws
The ones holding the chassis together? Black Philips head screws
Or something different?
Hello I' m talking about the screws which are used for closing all covers together, what I found here are to many different types of screws for sure not original
Only the one showing in the pictures, seems to be original.
This is a list of screws found on the service manual:
Top cover black: 6 screws 6-32 x 1/2" (12.7mm) Phillips pan head black;
sides black covers : 8 screws 6-32 x 3/8" (9.5mm) Phillips pan head black
Bottom cover black 12x 6-32 x 3/8";
All of them are not easy to find here in Italy.
Not sure what you have for US-spec hardware suppliers in Europe but McMaster-Carr definitely can supply those. Probably cost far more than the parts to ship and import though. I would expect any industrial hardware supplier to be able to get you these things by the bag for not-crazy money.
6-32 x 1/2" McMaster-Carr
6-32 x 3/8" McMaster-Carr
Ok I'll contact the shop, then ask for ship it in Italy, if the cost will be to much expensive, I need to find another way . thanks a lot for your answer .
Davide
