QSilver
I've recently been right through a CT-F850, all new capacitors and then carried out a calibration with a home made calibration tape that I verified with a number of other tape machines. I used a CT-F1000 to make the tape.
So far, everything has been great, and it sounds and makes great recordings which also playback just fine on other decks as you'd expect.
Until now... I got hold of a CT-939MkII. Now, it plays back my tapes just perfectly and I've been using it to play back tapes for a few weeks now. BUT.... When I record with it, weird things start happening...
I record something with the CT-939 and the instant playback sounds great. You play the tape again, sounds just fine. Now put it into any other tape player or for example my CT-F850, and there's a big drop in high end...
Maybe its misaligned? But how could it be if the CT-939 plays back tapes I've made on the CT-F850 just fine AND tapes it has recorded just fine too??
I tried passing some tones through the 939 as I was recording... 1kHz @ 0dB and 10kHz @ -10dB.
They played back okay in the 939 but in the CT-F850, 1kHz is on 0dB but 10kHz is at -15dB on left and -20dB on right....
So what's going on? Just need to calibrate the CT-939? Or am I missing something here?
All the checks were made with Dolby B on.
