CT-F1000 tape deck
donberry
bored so thought I would write a few reviews.
Pioneer CT-F1000 - was not Pioneers TOTL deck too long as it was soon replaced by the CT-F1250, but although not their best, the CT-F1000 is one really nice deck. Build quality is outstanding. That is not just all empty space in that big cabinet, it is a heavy unit for a cassette deck.
Pretty much standard controls for a high end tape deck with the feature that i use all of the time and really think helps keep the tape hiss to a minimum is the built in 400hz oscillator. Simple to use with the controls easy to get to, really no excuse not to do a quick check on tapes before you make a recording to get the best results.
Most people moved out of tape decks a long time ago and their memories of them is one of a lot of tape hiss. I would like to try to dispel that notion. Yes, they are not absolutely quiet between songs, but I have heard a lot more hiss in flacs then I have heard in one of my recorded tapes. You will not get total silence like you would with a good quality cd, but recorded properly, there should not be enough noise present to take away from the enjoyment of the music.
I have had a few people come over to hear some of my other gear and i always insure I have my tape deck ready to go. I never tell them what the source is until after the song is over. Usually when they check the gear out, the tape deck only gets a cursory look, more like a novelty item, plus the CT-F1000 really is a beautiful piece, but it is a tape deck after all.
Without fail though, after a couple of songs, I always let them know we were listening to a cassette tape - most have been stunned, some did not believe me. They had not heard a tape deck in ages and as mentioned above, all they thought about was tape hiss. They are always shocked that they do not hear more noise between songs.
It is by no means a dead silent quiet, but unless you are doing your most critical listening on a good cd with a good dac, you will not be disappointed.
Now it could be that they were recorded on the same model deck as I have now, but I have cassettes that were recorded back in 1978 that sound just as good now as they did when i recorded them.
Down sides are few in my opinion, with the biggest one being high bias tapes are no longer a walk in and buy item, usually have to buy them mail order.
Major upside, imo, no need to worry about the quality of the DAC here, analog thru and thru.
While the CT-F1000 was not their best deck, purely subjective here, but for me it was their best looking deck, but I say that as i am a big fan of VU meters over lights, just something about VU meters that trips my trigger.
If you happen to be in the market for a good quality tape deck that came close to matching the specs on many reel to reel machines, you could do far worse then a pioneer CT-F1000. It has always been my favorite deck, easy to set up and record with and stands the test of time.
Brief side - I believe one reason most people think of tape hiss when they think of a tape deck is they must have played a lot of pre-recorded tapes.
I personally have never heard a pre-recorded tape that even comes close to your own recordings. Pre-recorded tapes were mass produced and not set up for any particular machine. When you record your own tape on a hq deck, the settings are tailored specifically for that machine to get the best quality recording. While the tape will still sound better then a pre-recorded one on a different tape deck, played on the machine that recorded it, one is quickly reminded why audiophiles enjoyed their music back in the "old" days as much as they do now.
Not quite the same as watching those big reels spinning, but the sound of the CT-F1000 can come awful close to replicating the sound of the rtr's and unless you have very high end equipment, you may never notice the difference.
I have one and did a complete belt replacement. When I auditioned it it sounded very good and quiet to boot. Not yet reinstalled it in my system. Glad to hear someone thinks highly of this model. Looks like a good solid deck with the necessary features to make superb recordings. Glad I got it. Aside from the song access issue casettes still are fine audio pieces IMO.
I believe if you look on ebay they have complete belt replacement kits.
I will have to check my manuals, but would imagine it tells you how to do it(mine was done before I bought it). If it has the info, I can email the doc. to u
I have one but it hasn't been used in years. I still turn it on every once in a while to power it up and spin the motor. I know when I bought it I thought it was one of the coolest looking decks ever made. :thmbsp:
you can get the whole belt kit from wjoe here on AK and maybe on ebay. It is NOT an easy task as complete dissassembly is required and much must be remembered for reassembly, but if you're patient you can do it. study the instructions at each step. I did in about 4-5 days working intermitently. you get full instructions with many diagrams for help. the svc mnl is a waste of $ & time for the belt job. NO DETAILS. you need em. but you get 2 expanded dwgs with the kit from the svc mnl. for perspective.
That would be www.wjoe.com ask for ct-f1000 belt kit with idler bearing
An important part of rebuiding any of the Pioneer decks from this era is to take apart the take up clutch assembly and clean it, so it doesn't grab. I also snip one turn off the clutch spring to reduce the take up torque a bit. Makes the idler tire last much longer. I did this to my friend's CT-1000 back in 1986 or so and it's still working.
I also had a new CT-F1000 at that time...I agree wholeheartedly with your review. If I heard of AK 8-9 years ago, I'd have sent it to one of the restorers here instead of the hack shop that I did, and it still would be with me. I still listen to tapes made on that machine using Maxell UDXL-ll and TDK-SA.
My Yamaha K-1020 probably equals it, but it doesn't have the F-1000's silver beauty.
