CT F1000 Tape/ Source Selector Switch
miklemke
AK Subscriber
The Source/Tape selector switch is bad. It's part number is RSK 043. Any recommended replacement parts?
Thanks
Tape/Source Switch on CT-F1000
The web site www.partstore.com say they have it for 22.50. Try it. I have have about 50/50 luck with these guys, but it might be available. The usual scenario is to take your order and you either get the part or an email saying that it is unavailable. If you get one it is brand new.
Is it bad as in defective or maybe just needing some good cleaning with Deoxit? I would try cleaning it then go from there.
The switch itself is bad. It won't "switch" into tape mode. The travel of the lever is actually halted. I'll take the switch apart to see if it can be repaired.
I'll also try the partstore.
Checked-out Oaktree, they didn't have one.
Ordered one from the Partstore. We'll see if it actually arrives. Like mentioned above. They seem to hit on 50% of what is ordered.
If the one your getting does not work out, let me know, I have a deck I am parting out... 10.00 and the switch is yours.
CTF-1000 Tape/Source Selector switch
Well, I also need one of those switches and I decided to try the parts store.# Backordered!!!!# I will hang in there and see what happens.I have the same symptom.# The switch will not travel to the full up position.# I is like there is something in the switch that stops the travel.# Instead of going all the way up to be at 90 degrees from the face it goes to about 80 and stops.If you take that switch apart, I would like to know what is stopping the full travel.
I have a deck that I parted out also. The switch is yours if you want. My email is dennydog2003 @ yahoo dot com.
Denny
Scott sent the switch. I finally installed it, not an easy task. I'm now up and running. That was the problem. Sounds real nice.
Also had issues with the FF and RWD, but those have been fixed also.
I have another CT F1000 that I'll cover under a separate thread. That one has bigger problems.
Thanks for all the help.
