Tuquala
Just finished rebelting a CT-F1250 I recently acquired, all went well. Since it would not play before, now I am finding some problems I would like some insight into. Can't think that these were results of the work I just did, but it's definitely possible!!
1. Playback is muted, no highs. Also varies in volume. One quirk is that for a second or two immediately after you push play, it sounds pretty good, definitely towards normal, then drops down to whatever level it decides it wants to be at!! This will happen each time you select play.
2. It will not record, is getting signal on the input, BUT it is erasing what was on the tape previously. No sound recorded at all.
3. I can hear a very faint, rythmic high pitched tone from the cassette mechanism area. This may be normal, since the cover is off and it may be blocked with the cover on.
4. Other questions of things I found when doing the belt replacement: One of the small ball bearings (left side) under the "head base holder" was missing, and I replaced it with a slightly larger one. I can't see any sticking or twisting of the head base when engaging play. Sound ok, no problem?? Also, the service manual shows a washer (??) between the "idler guide plate" and the spring but there is no part #, is there supposed to be one there??
Obviously this one has had work or whatever done to it before, that is to be expected on older stuff. I know that I will probably need to o/h the idler drive motor, but right now it is acting ok, maybe from finally being used again.
Thanks for you help in advance!!
Gerry
Gerry
