Took my CT-F9191 to my local repair shop. Wasn't working either in FF/RW or play/record. Techs replaced the belts and demagnetized the heads, etc. But the play/record belt keeps walking off the drive motor shaft. They replaced what they'd put on with a slightly longer belt (which seems counterintuitive to me), but the same thing happens with it. I've removed the case and can get the belt back on and run it, but after a 90 minute tape or less, it walks off again. FF/REW seems to work fine.
I've ordered the WJOE belt kit and when I get it I'll try to install myself.
I've been through a lot of the CT-F9191 threads and can't find an identical situation. My thoughts are that the replacement belts installed by the local shop are just not the right belt. Seem right?
