spence0nasty
I have a ct-f9191 that had the common FF/REW problem and I think I may have created more transport problems in the course of trying to fix it. Right now the symptom is that the capstan/flywheel doesn't start turning when the machine is powered on. I'm creating this thread both to get help moving forward and to document my problems and progress. Here's a history that led me to this point:
I've been sitting on a ct-f9191 for a while. My band is about to release our first EP as a cassette (yes, it's 2020 and we're releasing a cassette -- small labels tend to favor cassette releases these days because they're cheap to produce) so I figured I should probably get it working if I want a way to listen to my own music...
FF/REW CLUTCH REPAIR -
The deck wouldn't FF/REW and after a quick search of my symptoms on the forum I came across this thread:
https://www.audiokarma.org/forums/i...ix-ctf-8282-9191-1000-rxa-581-not-diy.292583/
So I sent my clutch off to MTF to be repaired.
WJOE BELT & PULLEY KITS -
While I had the transport disassembled I went ahead and installed the WJOE belt and pulley kits (SKUs 848367 and 420003, respectively).
http://www.wjoe.com/vintageandantiques.htm#piocf
I got my clutch back from MTF, buttoned the transport back up and I was STILL having FF/REW problems.
TAPE MOVEMENT SENSOR & COUNTER LUBRICATION -
The problem then was that FF worked fine but REW would crap out in the middle of the tape. Through trial and error I found that if I removed the belt between the tape movement sensor and the tape counter REW would start working again. I found the following thread that described my problem exactly:
https://audiokarma.org/forums/index...rks-great-rew-struggles.469551/#post-13989986
I ordered some faderlube to lube the tape movement and counter shafts (posts #12 & #13). Due to COVID my order was delayed so I decided to move on with other improvements until I get the faderlube in the mail.
C807 REPLACEMENT (WRONG LEAD SPACING) -
I sprayed deoxit in the front panel pots & switches and decided to replace C807. C807 is called out by MTF as a common point of failure in this thread (post #3) so I decided to preemptively swap it for a WIMA film cap:
https://www.audiokarma.org/forums/index.php?threads/pioneer-ct-f9191-suddenly-stops.848066/
This is where things get dicey. I ordered a cap from digikey and the lead spacing ended up being too wide to be a drop-in replacement for the tiny sky blue Sanyo cap. I got creative and bent the leads in toward the center but when I soldered it in it wasn't a perfect fit. I didn't have any lead coming all the way thru the circuit board but I was still able to get the solder to form an okay connection.
CAPSTAN STOPPED WORKING -
I left the poorly-fitting replacement cap in there and turned the deck on to test it out. It worked! I listened to one full side of a tape and turned the deck off for the night. The next day I came back, turned the power on and the capstan didn't budge. Weird. I immediately assumed the problem was my poorly fitting cap so I ordered a new one. I purchased the following WIMA with 2.5mm lead spacing this time and it dropped in like a dream.
Still, after replacing the cap with one that fit the capstan doesn't move. I'll start by measuring power supply voltages, etc., but I'm wondering if there's anything else here I might be missing.
Code:
description mfg. p/n digikey p/n
WIMA 0.22uF 63V PET | MKS0C032200C00MSSD | 1928-1612-ND
