CTF-9191 Idler Arm Spring Replacement
DavidEngland
Hi folks,
I purchased myself a 9191 knowing it needed some work. I took it apart and began installing the WJOE belt kit.
Whelp, even though I read about it numerous times, I still managed to ruin the spring that connects the bottom of the idler arm. This is not the spring that connects to the center post on the arm, it's the one that connects to the 'holes' in the arm.
The spring is toast, it is stretched badly. I can't even bring it to a hardware store for comparison.
Any ideas? Has anyone else made this careless mistake:)? If so, how did you replace it? Part number etc would be a huge help.
Thanks in advance!
