relaximus
Consoles 'Я' Us
If you can't find any t-nuts locally, I've used these hurricane nuts from Parts Express and actually prefer them.
Dave
Dave
Dave
mr. biggles, i'm not sure what value caps you need for the crossovers, but if i remember correctly (when i dealt with a pair of highboys years back), they had a few caps with low value such as 2uf and one high value around 50-80uf?
i usually use cheaper caps with old stock oil caps to bypass them, and get great results. if you want to try this, i have some old stock bathtub oil caps. i'll send them to you for free if you want. just send me a pm with your address. i have used these same caps in recapping altec, jbl, and even tannoy crossovers with awesome results.
btw, the oil cap value is 0.1uf - good enough for bypassing.
ok, one more thing:
i just went through some boxes of spare drivers, and found the philips driver that may work in place of your mid-driver - if you can't get it to work. only thing is - mine is 5060 instead of 5061 and needs surrounds resealed, but probably practically same driver - 8 ohms as well. if you need this let me know as well. i'll ship it out to you with the caps.
Great thread. I was going to mention one more type of thread insert as an alternative to T-nuts: the brass insert nut.
You can get these at most hardware stores. Might not be just what you need for this project, just wanted to mention it.
Nice work!
nice to see someone giving a lot of time and efforts into these speakers. i'll ship out those caps and driver today. oil caps have three leads: one lead is marked "c" for common at the bottom. the other two leads are each 0.1uf, but i'm shipping four of them so that you can use just one in each place without having to share the "c" common's. as for the driver, it works fine, but cosmetically might not be better than yours. like i said, needs cloth surrounds re-sealed - just like those klh speaker woofers.
good luck with the rest of restoration and like many other have already expressed, you are awesome for restoring them! :thmbsp:
And now I'm thinking that I should actually have a new baffle made. I have the "patterns" and I know people second-hand that might be willing to cut me new ones. I just need to find some really snazzy wood. Something to think about over the next few days.
Thank you! I will be going in search of these when I have new baffles made. The old baffles don't have enough wood left in them to support these fine rigs.
Biggles
If you do decide to get new baffles made, mirror image them so the drivers are symmetrical.
I did this to mine and it helps the imaging a lot.
just flip over one of the baffles. The routing for the midrange would need to be on the other side, of course.
Hell yeah.
The Wreckedilinears LIVE AGAIN!
Crack a brew, and enjoy.
Whoa, I'm going to steal that one. Does anyone have a 3-D printer, I need new badges made.
