Current setup in Analog Room System Heathkit, Dynaco/ARC, 45 SET
kcline
Tube Audio Collector
This is my current " final" setup for this system. Each amp has its own set of speaker cables, to change amps switch speaker cables and inputs. On floor on marble stand is my 45 SET amp globe 45,s and 6J5-GT tubes with 5AR4 rectifier. Right behind is Heathkit W-3AM monoblocs, they are running 1950,s TG 5881, 1940,s RCA 6SN7-GT ink bottles and RCA 1950,s 5V4-GA rectifiers, Next up is ARC ST-70 C3, Modded Dynaco ST-70 amp, running Syl 6L6-GC Mullard and Telefunken 12AX7,s and Syl. 6FQ7 tubes. Speakers are 1973 Klipsch Cornwall's Verticals, tuner is Mac MR-78, Preamp is Fisher 400-C with Raytheon triple Mica 6201,s and Mullard 12AX7,s and Telefunken Smooth Plate 12AX7 in Phono stage. Turntable is Project Debut Carbon DC with Ortofon 2M red. Also i use with the Heathkits and ARC amp only, is my custom Bucker/ Variac which runs these two amps at around 115 volts. DSCN1619.JPG DSCN1621.JPG
