DownUpside
I'm looking to build my own power distribution box. And hoping that someone out there can help with a few points.
I'm getting a dedicated 20A circuit installed in my house later this month. And a whole house surge protector. So I'm looking to build a unit without surge protection or power conditioning. Just clean and simple power distribution.
I'd like to build a 10-outlet box using five Hubbell HBL5362 duplex receptacles. One of them will be un-switched, or possibly have a separate switch. For connecting to the wall outlet (also HBL5362), I plan to use a 12AWG shielded cable. I'm a bit of a novice when it comes to things like this, but my trusted audio tech has agreed to mentor me on this one.
So here are a few questions:
1) What's the optimal type of enclosure and material? Seems many go with machined aluminum.
2) Does anyone sell "blanks" for power distribution boxes?
3) How important is a ground terminal? Many (usually higher end boxes) have them. Many don't.
4) Better to somehow solder the power cable in directly or use an IEC socket?
5) Should I install a circuit breaker in the box?
6) I'm assuming each duplex should be wired directly to the IEC socket rather than wired in series.
I think those are my main questions. But I'm happy to take unsolicited advice too.
