I'm finally addressing an issue that started, round about ten years ago, broken speaker terminals on my Fisher CA-2120 Integrated amplifier. I've been using this as a pre-amp for the Hafler P500 amplifier since the speaker terminals were junk. After the first two, the A and B R+'s broke, I wired in a six inch piece of wire on each to be able to use it with my Tuner out in the shop.
I've since brought it in and found all of the plastic on the terminals was crumbling. I haven't been fond of the old spring clips since I discovered the Banana Jack, so I am determined to replace the old obsolete clips with something this side of the stone ages. Problem is, there's no room for them.
If I'm going to make this work I'll need to get creative, and ultimately never had to leave the comfort of thinking outside the box. Well, not since the solution was to stuff them in a box and screw it to the back of the amplifier in the old terminal plates place
