Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Hi
Ive lucky to been gifted a second hand Cyrus Lyric Stealth.
I currently use Quboz on my existing system streaming via the Yamaha Music cast app.
How do I go about using Quboz on the Cyrus I cant find any app and understand the Cadence app is discontinued?
You will see they suggest using mconnect, which should convert your phone's Qobuz output into a DLNA stream, then designate the Stealth as DLNA endpoint/renderer.
