Great idea 4343. As for the big caps you have, they would actually be reducing cab volume. Which is OK is you can spare it.
Tanks.
I've taken a few ideas from this thread today, some before even reading them!
So, I built a pair of Karlson 12" cabs a few years back, put EV 8HD's in nice matching boxes to sit on top... (Hold that thought a bit...)
Last year I built new top boxes for a pair of Pyle 6.5X12 waveguides, with D220Ti. Inside I put a >95 EW XO. (Hold that thought over next to the other one for a bit...)
Today I took them apart and replaced the 1.5uF's with a pair of 3uF's standing on their ends, the middle being tied to a 2.2M ohm resistor.
Then I took out the 4.7uf and replaced it with a 10uf and a 9.5uF (all I had on hand), standing on their ends, the middle being tied to a 2.2M ohm resistor. The two resistors are tied together and fed to a 9V battery box, positive side. The negative side of the battery is tied to ground at a convenient point, which was the wire feeding the L-Pad in my case. (Pin 3 IIRC.) After playing them for a few CD's worth of time over dinner, I slipped a 9V into the battery box. Playing Dire Straights through one* of them now. Sounds wonderful!
Tomorrow I will do the same to the other, but I will have to wait for some 9.1uF's to get a stereo pair.
So the answer to the question about fitting them onto the circuit board is, change values to double what you have now. <95 =4.7uf and .47uf, the CC schematic shows this as 9.1uF+10uF and 1.0uF+1.0uF, vertically, they should fit.
* The other side is my LE-10A with 8X8 waveguide the Zilch was kind enough to post a crossover for somewhere.:tresbon: I've got them running bi-amped, so it was a simple matter to unplug the HF cable and plug it into the top box. C-C? Huge! Which is why I gave up on the Karlson cabs so long ago...
