rocksy
Hi all,
I've seen a few posts where people ask about something that can take the HDMI audio signal from a TV's ARC-out, and convert it to an analog signal for use in an older receiver.
I'm putting together thing as follows:
Apple TV --(HDMI-IN)--> Samsung TV --(HDMI-OUT [ARC])--> DAC CONVERTER --(RCA-OUT)--> NIKKO NR-819 Receiver
The most important part of this setup though is that the volume can be controllable by the TV's remote (volume control be passed though the HDMI's arc protocol to the DAC, which raises/lower the analog line out going to the receiver)
I bought the following last week: CAMWAY Digital to Analog Audio Converter
...everything worked, except the bass was extremely muddled and scratchy. Anything in mid/higher frequencies sounded OK. Anyway, I am returning it as ithe sound quality isn't good enough.
I'm willing to give this another shot though. There is one other real option on amazon(HDMI ARC to Analog Audio Converter, Tiancai) but I'm concerned I'll run into the same issue. SHARC eARC Audio Converter also exists, and the price suggests that it would function better, but it's a bit out of the price range.
Are there any options for an HDMI DAC with volume control that does not suffer from audio quality issues? Or is having a volume modulator included going to result in the same muddled bass issue that I've experienced? I have good luck with optical -> analog converters in the past, but these do no offer remote control volume control.
Thank you,
yannikrock
Thank you,
yannikrock
