Thanks, spark1.
You are spot on. I’m more than slightly confused. I’m not very versed with tech and new to this DAC game. That’s after all why I’m here.
Since you seem to have a good understanding of it, can you explain the below?
I read of people using an external DAC in addition to the Pro Plus in their system. Why?
Some users have "better" DACs than the one built into their Wiim. More specifically, they have a DAC that they prefer. There is certainly variation in the sonic characteristics of various DACs. So, they use the Wiim to manage the streaming function, but bypass its internal DAC and use the one they prefer. They do this by taking digital
output from the Wiim (via its coax or optical connections) and sending it to the external DAC. The external DAC then does the digital to analog decoding and first-stage analog amplification.
The Wiim specs are stated as follows:
In: Analog and optical: up to 192kHz/24-bit
Out: Analog, optical and coaxial: up to 768kHz/32-bit.
In this context, 'input"refers only to local inputs...NOT to the music being streamed from "the cloud".
The Wiim has analog inputs;, in the form of L/R RCA jacks. These would be used for analog signals, such as from a turntable, tape deck, amplifier, etc. The Wiim converts the analog input to digital, using its built-in ADC (analog to digital converter). The resulting digital signal can then be sent to a downstream device, using either a) the Wiim's digital
outputs, or b) its analog output, in which case the Wiim's built in DAC is converting the signal back to analog.
The Wiim offers two options for digital output: a) coaxial, and b) optical. I interpret the 32/768 spec to apply to the ability of the Wiim to process PCM music files of up to 32 bits and sampling rate of 768K/second. In other words, the Wiim can both a) convert 32/768 files (and anytthing below that) to analog, using its DAC, or b) stream 32/768 files and pass them in digital form to an external processor (using its coax or optical outputs).
Since the out values can be higher than the max intake values, are we upsampling?
For example, what exactly happens with a (digital) Tidal high-res file when it gets to the Wiim, and what resolution (analogue) data comes out of the Wiim (and is sent to the receiver)?
When does the DAC’s capability of sample rates of up to 768kHz/32-bit come into play?
As I stated above, input specs do NOT apply to data being streamed.
In your example, the Wiim connects with Tidal and establishes a streaming connection. Tidal sends the requested music file, and the Wiim converts it from digital to analog. The notion of "resolution" does not apply to analog, at least not in the form of a bitrate.
The DAC's ability to handle 32/768 files comes into play when it obtains a 32/768 file.
So yes, it is very likely that I may have a fundamental misconception somewhere.
Happy to be lectured.
