It depends upon which model of the DQ 10 early ones had all electrolytic capacitors later ones had the mylar capacitors and one electrolytic, and then the mirror image speakers after that and the stands being non-standard it would be up to you if that is something you would consider a plus.
they made 25,000 pair of the speakers so they’re 50,000 of them out there. This gives you an idea of the serial numbers but in good shape they’re probably worth 300 US and with the later improvements may be up to 500 with stock stands would be a fair price. The serial number sticker on the early models was up on the tweeter plate on a small piece of paper and the electrolytic capacitors were replaced at about 22,000 and the mirror imaging started at about 29,000 for the serial numbers.
I don’t know about pricing where you are but I found DQ-10s listed anywhere from US$200-$700 for a pair. You might expect to have to refoam the Advent type woofers and replace the 80 µF cap that goes to the midwoofer if you have the mylar caps in the speakers, because that cap is an electrolytic. A full recap if all electrolytic.
