SmartPDX
Hello,
I have a pair of JBL L100A Century speakers
One of them has a damaged LE25 tweeter (please see attached picture).
I am uncertain what path is best.
Repair it...if so where? are there viable DIY options?
Replace it...if so buy another used one? or is there a new option as good or better...again where?
In addition to that issue the foam on both tweeters is decayed and am hoping to know the best resource to buy a replacement kit? are they all the same or is there a good/better/best aspect to the choosing?
I also have seen some using a neoprene type material instead of foam...is this better or considered wrong or not OG for the JBLs?
I am also uncertain if I should just replace the foam or also the thin cellophane type material under the foam as well? is this necessary? or leave it alone? if so where to buy that?
All thoughts welcome.
Thank you.
Thank you.
