Unda Maris
Mr. V-FET
What Kenwood called Sigma Drive is nothing else than a sense circuit which extends the feedback loop to the ends of the speaker cable.
But this approach has a huge drawback:
If you don´t use a special low inductance cable, the amplifier starts to develop an tendency for oscillations, because the cable itself introduces servere phaseshifts at higher frequencies (well above the audio spectrum but still quite low frequency ).
Since every amplifier has a certain phase margin, which allows a certain open loop gain and a certain open loop bandwidth, the additional phase shift of the four wire feedback will force the designer to artificially reduce the open loop bandwidth, in order stabilize the amplifier.
All amplifiers I know, which allow such four wire cables of several feet length have an open loop bandwidth, which is well below 20kHz, sometimes even lower than 1kHz.
This means that the DF of these amplifiers at least doubles every octave above this corner frequency. Lets say the amplifier has e.g. a DF of 1000 and a 400Hz open loop bandwidth. This would mean that the DF decreases down to 100 at 4 kHz and 20 at 20kHz. These are realistic figures for such amplifiers !
Amplifiers with lots of NFB and very low open loop bandwidth also tend to be unable to control crossover- and switching distortions of the output stage and produce all these bad TIM, IIM and Differential tone distortions.
I don´t think, that Kenwood was able to deliver a DF of 1000 at the end of a ten feet cable at 20kHz ! That sounds impossible for me !
The tube amplifier doesn´t see any (or only a defined small dummy-) load in this setup, which reduces load dependency to almost zero.
