Dana Audio Model 2F
GrndotGator
I just picked up a pair of these, tore them apart and am in the process of rehabbing them. One tweeter flange was cracked up, no way to screw it down. I found replacements at Madisound and ordered two. The crossover does not look original, it has electrolytic caps and a 1st order crossover with a notch filter on the woofer. I did find info that Dana used poly caps in the original xover. I can not find any other info on the crossover. Anyone have info on these? I need crossover frequency and hopefully a schematic of it. I know the tweets are 6 ohm and woofer is 8 ohm. If all else fails, I'll build a new 2nd order xover @ 2.5kHz, that should give them a nice warm sound.
I got them back together with a (temporary) Niles HD-800 xover in it, caps indicate it is @2.5kHz. They sound very impressive as is but would like to get them back to original.
