buickguy62
On the large auction site is a Harman Kardon A700 amplifier for sale. In the description the seller notes that one of the can capacitors has a red X on it "not because it's bad but as a warning against touching it while the amp is in operation." It is a replacement for one of the voltage doubler caps and is not the proper insulated can, so yes you should not touch it--the voltage on the can is over 200 VDC!! I emailed him and explained the problem, that contact could be lethal, and it should be replaced with a proper cap (could mount a replacement under the chassis), or else cut off the power plug and sell it as non-functioning. He replied that in the description he states that you should not touch the cap, and added that he plans to put a piece of plastic pipe over the cap. Am I overreacting--I can imagine someone new to tubes buying this with possible tragic consequences. If you look for the listing there are 2 Harman Kardon A700's for sale, this one has 'fully working' in the title.
