Hello all.
For some reason my dbx bx3 mk1 keeps frying the outputs.
All started last week when the input cables came disconnected from the amp and killed the amp. After some help from some members here, found out the problem. Resulted in the 3.9 ohm resistor in the protector board and 4 outputs blown in one of the boards. After being resurrected worked well for a day and suddenly start smoking again. This time again the resistor was bad and again the outputs were blown. After replace parts it happened again and blew up this time a resistor that is connected to the transformer secondary black cable and that goes to gnd, and blown outputs again.
After replace those parts again all happened again.... I am really clueless... anybody has any idea what can be wrong? Any help will be really appreciated. Thank you
