Carbsandcaps
Working on a kr-750 and the protection relay won’t come on. Testing around and I found 12v on the collectors of the output transistors. I can’t find anywhere it would be picking up 12v. The base and collector have the correct voltages. Is there any way to check for where the voltage is coming from without disconnecting things one at a time? The dc offset adjustment does not change the voltage.
