Has anyone posted pictures of the 'unsocked' speakers?
I have a separate thread already started and have been taking images, as I go along, and will post soon, maybe today if I find time.
First, yes there are two woofers. The reason you can't see the second is the felt that is between the tweeter plate and the plate covering the woofer. No light will get passed the felt so you can't see the woofer. However, if you look close enough at the edges you might see the outline of the frame and maybe the screws.
Second, don't go top to bottom, as pointed out you are going from narrow to wide and if the fabric is worth keeping it likely won't be after you stretch the crap out of it pulling it down.
Mallet is the best, and safest way, however, placing a block of wood against the bottom and hitting that will distribute the blow better. Of course tapping and not swinging "for the fence", as they say.
The rear port is a major pain. If any of the material was sandwiched between the port and the opening you might break the lip of the port, I know cause I did. Fortunately I was able to repair it, but it still shows.
I'll show the liner's/covers/socks (whatever you want to call them) as well. Also I used foam picked up from JoAnns fabrics for the baffle. Again, once I post images it will make more sense.
It's a lot of trouble/effort, but replacing the foam, I believe, is a key component to getting the best sound out of these. The foam, I'm pretty certain, was functional in containing reflections off the baffle to a minimum.
Anyway, with the exception of my opinion on the foam, this is all fact, I know cause I'm nearly finished with the "restore" so to speak. Thankfully all drivers are functional and sound great, so far. I just wish I had a more suitable room to test them, but they're for a friend so no worries.
