CygnusDen
And so it begins...
Anyone ever thought of removing this? Seems to me this would hinder optimum performance from the driver directly behind. Any thoughts? I'm guessing, only, that this may have been to control vibration of the metal screens?
That's certainly an easy mod to try out and reverse if you don't like the results. I assume the felt doesn't hurt performance, and it may actually be important for some reason beyond controlling resonance of the metal screen. Why don't you give it a go and report back on the difference?
I have never been tempted to do this primarily because vintage DCM designs seem to be pretty carefully thought out. Also, I have learned the hard way that DCM construction methods are not at all friendly to tinkering around. Socks get stretched out and never look right again, foam pieces disintegrate, drivers are frequently glued in and can't be removed without ripping out chunks of particle board, screw holes are easily stripped, metal masks get bent if screws are tightened just a bit too much, etc. Having learned my lesson, I now try to leave them alone and just enjoy the wonderful sound they produce
