chicks
Lunatic Member
Just picked these up at the GW today. Tested them at low level, very nice "open" sound to them. Dunno how to describe, but they don't sound "boxy" at all - sorry, not familiar with audiophile terms...
Definitely noticed distorted sounds on the low end, although was kinda surprised they had any bass at all, considering the small drivers. So, researched how the heck to open these puppies up. Most of what I read made no sense in relation to these: "remove the foldout foot and bottom, then roll the sock up", "use a block of wood and hammer to knock the top off, then roll the sock down". Problem is, the "sock" is behind a piece of black-painted particle board that covers the entire back, so no way was the sock gonna roll up or down with that in the way.
So, removed the 12 Philips and 1 square/slot head screw on the back, popped the red and black wires from the entry cup, and the back came right off. Through a hole in the sock just behind the woofer, spotted two hex-head bolts holding the top on. 7/16" ratchet socket wrench removed those, and the top popped off. Now, just carefully un-peeled the "sock" (looks more like panty-hose to me) from the black fabric under it, and finally, was able to roll the sock down to expose the drivers.
Sure enough, foam rot. Project time! Anyone know the correct kit for these? Please consider that I'm a complete newbie at re-foaming (had Neal do my NLA's), so a complete kit would be required, and that the cardboard gasket on the front of the woof is coming unglued, as well. Or, would it be just as cost-effective to replace the woofs with something with rubber surrounds? Woof is marked 5 ohms...
