DCM TimePiece Specs
Wolverine
AK Subscriber
Well finally off the road for a while and now have time to play with some new toys...... :banana:
I picked up a pair of DCM TimePiece speakers for the rear pair in my all DCM HT. Nice compact little speaker with good sound. I am looking for some specs on them though. My search here seem to indicate they have a 6 1/2 inch woofer but even shining a light through the grill cloth I can't confirm. There is no grill to remove so all I could really see is a wire mesh screen and a port. Is there a tweeter mounted behind the woofer? I did go to the DCM website and there is no manual listed for this older version of TimePiece. Any info would be appreciated.
Thanks!
Not too many TimePieces out there. I had never heard of them before I found this Forum. Wish I could help.
KB
I know what you mean. I was ignorant of DCM unril about 2 months ago. The TimePieces are from what I can tell their smallest offering and there does not seem to be much out there on them. I was hoping someone here had a manual or access to a manual.
Well I have had these hooked up now for a couple of days and for their size they are pretty good even though I do not have them sitting in optimal listening position. They have the usual good imaging/depth of DCM speakers and pretty decent bass given their size. Not as good as the TF series but I would highly recommend them as fronts in a small bedroom/office set up or surrounds in HT.
Got a reply from DCM today.
They sent me a copy of the owner's manual.
I can't attach it but I would willing to e-mail it to any Timepiece owner's who are interested. Brief recap;
Sensitivity
90db/1 watt/1 meter
Recommended Power
10-80 watts
Maximum Power Handling
15 watts RMS pink noise continuous
100 watts peak program
Frequency Range
60 to 20KHZ
Enclosure Type
Transmission Line
Resonance 48 Hz
Drivers
6.5" low frequency driver
.75 plastic dome tweeter
Tuned Port
It's nice to know that there is some info on these speakers, as I have a pair that have absolutely no highs, only some muffled mid-bass.
It would be nice to find out how to open them up to check out the insides . . . :yes::yes::yes::yes::yes:
Cheers
Actually the half time is the smallest in that family, i had a set with a matching subwoofer. The halftime's are about 1/2 the size of a timepiece if i am not mistaken. using a 6 1/2" woofer and a coaxial mounted tweeter. The enclosure was not much taller than the woofer mounted in it. They were acoustic susupension not ported or transmission line.
