IEHAGY
It started with louder than normal noise floor / hiss that I was able to control by adding a passive preamp into my chain ... then it started taking longer than normal for it to heat up .... and now it wont heat up at all.
I'm wondering if its time to take my beloved Juicy Music Extreme to a tech or if perchance a better first step would be to try some tube replacements on my own.
This particular preamp has 4 tubes I can see .. 2 12AT7's, 1 12AX7 and a what I think is a 6h30 supertube.
After taking off the clothes, and let it power on for about 30 minutes ... the 6h30 gets HOT, one AT7 is HOT and the other is WARM. The AX7 however, remains completely cool to the touch.
I am a pretty big novice at this but would it be worth replacing the AX7 or should i be safe and just go straight to the shop ( speaking of which, any good ones in LA ) ?
Appreciate the advice, thanks.
