Thanks. I made the suggested changes and they look good. I have a new problem though, when looking for a replacement for
Mouser #: 598-DSF050J474
Mfr. #: DSF050J474
Mfr.: Cornell Dubilier
Desc.: Film Capacitors 0.47uF 50V 5%
I didn't notice the Wima equivalent is a non-stocked item at the 5% tolerance, but is available in 10%. I'm assuming 5% is required. They are used on the tuner and mic boards only.
Both Nichicon (647-QYX1H474JTP, $1.16) and Kemets (
80-SMR5474J50J0416, $1.97) are available.
You're doing a great job with looking up the replacements and dealing with the existing BOM. Keep it up!
Try this approach and see how it works for you:
You know you need a through-hole (not surface mount) film capacitor. You probably want a radial set of leads instead of axial ones (that's old gear, not the "modern" solid state gear like your 737). You know you want 0.47 uF and you need 50 VDC or more.
Try searching on Mouser using these sequential steps:
Passive components
Capacitors
Film caps
Through-hole
In-stock
Radial
0.47 uF
At this point, you should have LOTS of matching choices. Now is when you can start getting picky and use your own judgement or favorites.
I like Panasonic for this range of capacitance in film caps, so I limit the results to Panasonic.
You're really just interested in polyester or, maybe, polypropylene, so limit the results to polyester as the dielectric.
You should be down to about 25 choices, in stock, of Panasonic ECQ series film caps. All of them will be way more than 50V capable. If they aren't, filter to just show those 50V or higher.
Now you need to take into consideration just two things: lead spacing and physical size.
Look at your PCB, measure or guess at how far apart the holes for this cap are. They'll be 5mm or 12mm or maybe even 15mm. You want to choose a Panasonic ECQ series with lead spacing to match or nearly match your PCB holes. Remember you can bend the leads inward or outward, so you don't have to match this exactly.
Next, look at the width and physical dimensions. Nice caps like these Panasonics can get quite big, so even if your lead spacing is close enough to get the leads in the PCB< you might find the physical cap body is too big to fit in that spot on the PCB and not shove other nearby components out fo the way. So, just look at the physical dimensions listed on Mouser, lokk at your PCB where this cap goes, and get one that you think will fit. One or two sub-series, like the ECQ-B or something, says "smaller than normal" in the datasheet. I prefer those so I can avoid crowding when I choose replacement film caps.
Does that help? When you try the above or just the parts above that make sense, are you getting good choices in your search results?
