Rob_Feature
Rob Feature
I know this is a really unorthodox question...but here's what I've got:
I'm taking an old transistor radio that looks cool, gutting it, and putting bluetooth inside. Pretty common project but note that I'm not using the transistor radio's amplifier...I didn't feel like figuring out the right way to wire it..I'm just using the cheap-o amp that comes with a bluetooth speaker. So I bought a $5 bluetooth speaker, pulled out the module which expects a tiny 4 ohm speaker, and cut the speaker wires.
I want to use the speaker that's already mounted in the transistor radio. Only problem is that speaker is rated at 10ohms.
Is there a simple way to lower the impedance of the 10 ohm speaker down to the 4 ohms that the module expects? I hooked it up directly at 10 ohm, thinking it should just be quieter (if I'm thinking correctly, a higher ohm speaker never will damage the amp, it should just require more power to drive it, right?)...it worked when hooked up, but distorted at a pretty low volume.
So, any simple options here? Some way of wiring it or adding simple components to lower the resistance to the expected 4ohms? Please note this certainly isn't an audiophile project...I just wanted to make a cool looking cheap BT speaker. So simplicity is the key here! Thanks!
