Hello
I bought ab defect Thorens td-125 and they don't know what's broken.
I didn't test if other speeds are correct with a phone. But it was not turning at 45 at all.
I changed those big capacitors with panasonic 25V1000UF. I don't understand much about electronics so it was my first soldering.
Also there was a crack on the board. I scraped the paths that the crack was cutting through and soldered. Continuity test passes. But Another question is, when I test continuity, the connector where it says A2 doesn't beep with the copper wires. I don't know if it's the connection I should be checking. But just the coppers on both sides of the crack beeps OK.
At 45 rpm, it's still turning unsteady, nothing changed:
All the cables are so old and looks like it was never serviced. I will change the audio cables, spray deoxit to connectors, oil bearings next.
