Deletion of posts
Tripod
Well-Known Member
Hi
I have just posted a reply to a member's enquiry about external USB souncards. I wanted to upload a pic of the device I use but the pic didn't want to load for some reason or other. So, I posted another reply and again had trouble uploading without success. The same pic is sized correctly for here.
I then thought it would be better to delete both posts and tried the "Edit" function. I found it is not possible to delete. Is that correct or am I doing something stupid?
Cheers
tripod
Tripod, you will need to contact the forum mod to get posts deleted unless you are a subscriber. You may edit content, but not delete if you are a normal member.
Next time, Tripod, use the patented OvenMaster® non-subscriber post deletion system. You can edit to your heart's content, right? So edit out EVERYTHING and put the words
*deleted by Tripod*
or
*edited by Tripod*
in there. Look at the next post.
Not only does it delete your post, it also has the extra side benefit of keeping your post count up! Subscribers don't get that fringe benefit! :D
Tom
