Hi. Just seeing if anyone is interested in helping a rookie learn a bit. I have a Denon AVR 2105. Given to me so I have nothing invested in it, just want to use it to learn. Guys son was cranking some tunes one night and it shut off. It goes into protection mode seconds after turning on.
1. I have tried the reset. Nothing
2. There is a video on youtube with an experienced tech guy fixing the exact same model. His was a rectifier problem. I took both rectifiers out and checked them with my DMM and they seem to test fine.
3. Some other Denons have voltage regulator issues. I used the DMM to test what seems to be the five main ones, they seem to test fine.
I can't see anything that seems out of place. Saw some smoke come from a resistor as I tested it so I will change that out, but it was long after the problem occurred so I don't think it was the original problem.
If I can figure it out fine, if I learn a few things good, or if I end up just stripping it for parts that is fine too.
Let me know what you think I should check, and how
Thanks
Thanks
