After having done all of that I got into a discussion with HypnoToad about adding a 0.1µF film cap across the supply lines of the op-amps to stabilize them and damp oscillations. I tried that first on a DCD-1290 and liked the results. There was a measurable drop in temp in the op-amps and another small improvement in overall clarity, including a little tighter bass. So I did the same to the 2700 units.
Actually I figured that if adding the film caps to the op-amps in tha analog section, would it be of use to add them to the op-amps in the digital section that are acting as motor controllers? It didn't seem like that it could hurt and so I added the 0.1µF/63v Wima MKS2 caps to all of the op-amps in the entire player.
View attachment 866802 View attachment 866803
I like this. Another incremental sound improvement. And when I was working on the 2nd player and paying a bit more attention I could see that the pcb was discolored from heat under all of the op-amps in the analog section. So I think that adding sockets for the op-amps might act as an additional bit of heat sinking to protect the pcb from heat damage, as well as the stabilization film caps.
Cheers,
James
Nice Job
But... 0.1µF film cap across the supply , in pin 4 and 8 ??? This is for single supply line, not dual.
If you got +12v in pin 1 and -12v in pin 4... then the decoupling is with two capacitors.... one in pin 4 to ground, and another in pin 8 to ground
I am wrong ??
