Denon DL-110 headshell spacer weight
johsti
Does anyone happen to know how much the Denon DL-110 Headshell spacer weight weighs? I'm referring to the small weight that comes with the cartridge and sits between the top of the cartridge and bottom of the headshell.
Is anyone using this spacer weight on a Technics 1200 with the stock headshell? I have the KAB tonearm resonance cap on the back of my tonearm and have found that I need a little more weight at the headshell to properly set VTF.
Thanks
I have not needed to use it with my DL-160 on a 1200 with resonance cap, with 1.6g VTF. I'm not sure why you do - is the DL-110 that much lighter than the 160?
I think the 160 and 110 weigh the same, but I run about 1.9-2.0 VTF with the 110. The recommended vtf for the 110 is 1.8 +/- .3 which is slightly higher than the recommended 1.6 for the 160.
the weight that came with my dl 110 is .7
EDIT: i re-weighed the weigh, mine is 1.4
I am using it in my stock sl 1200 headshell.
Currently I'm removing it to try and hear a difference.
