Denon DP-37F Score with a problem
Cactus Bob
Desert Rat
I picked a Denon DP-37F today. The TT is perfect cosmetically, even the dust cover. When you press the power button the motor makes a humming noise and the arm moves only slightly and the platen does not revolve. Any ideas? It has a DL-160 cartridge on it but it's missing the stylus. What is the consensus on these units soundwise etc.? Thanks Bob
Hate to say it, Cactus, but this TT has a pretty sophisticated Servo system which controls the platter and tone-arm. I own the the same model and I purchased the service manual and was blown away by the amount of documentation and complexity. The fact that your motor "hums" and doesn't spin is a bad sign. Other than a simple mechanical problem (like a frozen bearing on the base of the spindle) I'd say you have a serious failure. If its not that, you're going to have to spend time and $$ to get it repaired, and most likely that's going to be difficult. Not to burst your bubble, but you have a DOA scenario there.
Bryan
If you decide it's a total loss, I'd be willing to purchase the headshell off the tone arm for the cost of the TT. PM me if you're interested. Thanks.
Bryan
It's a nice TT if working, especially as a starter TT or for a second system. Don't remember if the Vinyl Engine site has any manuals for this specific table, but it may have manuals for similar TT's like the DP-35F. The servo tonearm is nice & you can use most any cartridge on it.
If it's direct drive, does the rotor under the platter have locks on it for transport?
I'll have to check that, thanks
It's a nice TT if working, especially as a starter TT or for a second system. Don't remember if the Vinyl Engine site has any manuals for this specific table, but it may have manuals for similar TT's like the DP-35L. The servo tonearm is nice & you can use most any cartridge on it.
They had the owners manual. I'll have to study this TT closer this weekend. Thanks
I have one - it's now a parts unit! Same type of thing happened to mine - just stopped spinning, I don't think it's the motor tho. Probably something on the pcb, maybe a bad cap throwing things off. I bought another DP-47F so my DP-37F is sitting. Sounded GREAT for the few years I had it working. I even thought it sounded as good or even slightly better than it's replacement. Since you just got it - I'd see if you can fix it, but I couldn't tell you what to look for. It's a direct drive model with no belts - the motor spins the platter with a type of magnet drive. Lots of electronics for a TT under the cover. Try Vinyl Engine for a service manual.
Cheers,
Bob
Cheers,
Bob
Thanks for the info, it looks pretty bleak now. It's amazing how quality & building techniques changed from the late 70's to the early 80's. Not for the better I guess. Bob
I recently picked up a mint DP-60L and I love it! Member Pio1980 seems to know quite a bit about Denon TT's... perhaps you should contact him.
Steve
Steve
I think your TT is in a different league then this one. This one being at the bottom. I opened it up a little while ago and yikes!! There is a lot of electronic junk in there!!
I'll contact Pio1980 ya never know, thanks bob
Yes, the "L" series was a cut above the "F" series.
Thanks for the explanation!
I have often wonder why some Denon DP-xxF model seem more work horse like and lack the electronic sophistications.
Actually I did not realized that there were two separate series, the L and the F. :D
Just for clarification for anyone who comes along after, "L" meant automatic LIFT at end of record, "F" indicated Fully Automatic, and "M" indicated totally manual.
