Pacoloco
My trusty Denon dp59l turntable has developed a sudden very noticeable Buzz from both channels. Wiggling the RCA connections on the back of the preamp does nothing to affect the buzz and it is equal in both channels. Each lead from the turntable cable carries the noise even if the other is unplugged . The buzz is present whether the turntable is powered on or not. However, powering on the turntable increases the volume and intensity of the noise. The noise increases with volume increase of the preamplifier. I have tried several preamps and receivers and two different sets of speakers to rule out those components. Disconnecting and reconnecting the ground wire makes no difference.
any suggestions?
any suggestions?
