henkjas
Hi there, greetings from a newbie on audiokarma,
I recently got a Denon DP47-f record player. It is functioning fine but I'n struggling with the arm adjustment. Using this forum I understood how I can set the lead in for 30cm records. It's quite simpel, using a small flat head screwdriver through a hole near the arm assembly. But when I have set the correct distance for 30cm, I noticed that for 45rm (17cm) the needle drops something like 2mm to far.
Now there's a small section in the sm that talks about this.
- first set the adjustment for 30 cm (i did)
- determine how much the lead in for 17 cm is off (for me +2mm)
And here starts the tricky stuff
- take off bottom cover and check the adjustment scale position
- one adjustment scale corresponds with 0.5mm
- untighten the adjustment screw holding the sub-shutter, place a small flat-headed screwdriver into the slot of the shutter
- make the adjustment, and the tighten the adjustmentscrew again
That should do it. There's a picture with it.
So I can see the sub shutter, i can see the sub shutter screw, but as you can see in the picture, the sub shutter is fixed with some glue like stuff.
I can put a flat headed screw driver in that rectangular hole (as mentioned in the sm) in the sub shutter but I cannot move it.
Also I do not see the "adjustment scale" as mentioned in the sm. The place to put the screwdriver, there seems to be nothing there.
I wonder if someone knows what to do. I did remove the small pcb above the shutter part but also did not see any scale.
Should I remove the glue stuff over the sub shutter? It seems to be missing on one side. Or am I looking in the wrong place?
I think this picture from the sm is not the same as what I am seeing in the turntable.
Here is a pictures in more detail:
You can see one side of the sub shutter is slightly over the edge of the plate beneath. Maybe that's what I have to work with, I'm not sure.
Any help is much appreciated.
Regards, Henk
Regards, Henk
