jerdobi
This is an interesting sometimes works, sometimes won't.
When the amplifier is on the bench it works fantastic. I button it up and play it in my rack with no issues. 24 hours later, power on and hear the power relay kick in, red led blinking for a few seconds and then goes full red; but BOTH power relays are disengaged. I've tried a bit of bumping
and no response. (repeat this paragraph 2-3 times
Take it back to the bench and see same issue.
Decide to look at the protection board behind the bottom cover.
I turn the amplifier upside down remove the bottom to look at the protection board. It looks good with no noticeable issues, all capacitors are high quality caps with no bulges. Well, turn it on while upside down and low a behold it starts working.
Put back the bottom, flip back right side up and still working.
My diagnosis is there's a loose connection, but can't see it as this thing is solid with literally no loose wires, just connectors. Whatever the issue, it shuts down both channels and I don't think it's a relay.
Anyone seen this symptom on a PMA-2000R or PMA-2000IVR? Maybe they work better upside down?
Thanks!
Thanks!
