Denon PMA-520 right channel not working
tomferno
Hello,
I have an old Denon PMA-520 amp and I have never had such a good sounding amp.
Recently I had an issue when I select the Source selector in "Normal" or "Subsonic" mode, there is no sound on the right channel (or very quiet). But when I use CD-Direct everything works fine.
I tried to invert the speakers and it's the same thing, so the speakers are fine.
I cleaned the whole amp with contact cleaner on the inside. The issue was solved for about 1 or 2 days and it came back :(
Does anyone have an idea from where this issue can come from ?
It would be a mess to throw this amp away as it's such a sweet sounding amp !
Thanks
Tom
deoxit d5 on the source selector,tape monitor and the buttons. work 100-200 times
deoxit f5 on potentiometers. work each 100-200 times.
contact cleaner dries too fast to really clean anything cruddy or for very long, as you saw.
so you think it's just a switch contact problem or a balance poti problem ? Nothing with an old solder issue ?
it could be a solder joint on that switch.
now i see that you only cleaned the inside of the amp with contact cleaner, you need to get the chemical in the switches.
will try this out. I found the Deoxit products on a german site.
Thanks for your help. I'll keep the thread updated
i just took a look at some pics of the inside, that switch is cable driven. get some contact cleaner inside the switch itself and work it a couple dozen times and see how it goes.
it's white in the pic i saw, back by the inputs
