aaronhoyle
I have both a PMA-750 and soon will have an AVR-4802R that I am being gifted.. the PMA-750 sounds fantastic, however I have had an issue recently where one channel is randomly dropping out (not affected by rotating any pot or switching any toggles, also happens to both A/B speaker outputs) and will later suddenly reappear and work flawlessly for another several days before dropping out again. When the channel drops it produces a low level hiss not heard on the other, working channel.
My question is (assuming the PMA-750 is working properly) which unit would likely sound better for 2 channel operation? The 750 has impressive distortion specs and is dead quiet. The AVR-4802R, although designed primarily for HT use, was clearly built with high quality components and has been tested to have ridiculously low distortion (see https://hometheaterhifi.com/volume_11_1/denon-avr-4802r-receiver-2-2004-part-2.html ). The unit also has a 2 channel pure direct mode which turns off the video circuitry and other components that can interfere with the signal.
I also have a 3rd option, using the AVR-4802R as a preamp with a Parasound HCA-1205A. What would seen to be an obvious choice to use this configuration is blurred by the insanely low distortion figures produced by the 4802R's amp section... lower than the Parasound spec'd, I believe. However, distortion isn't everything....
What do you think?
What do you think?
