Hi all
Got this Denon PMA-860 recently.
It has a problem with the input selector switch and balance control.
To select a source you need to rotate a knob few clicks past a desired selection in either direction. This makes the last ones on the right and on the left unelectable.
Left channel has a very low distorted output. But if I switch on Source Direct to bypass balance, both channels work well.
I tried to upload the service manual but file is too big. It can be found here https://www.electronica-pt.com/esquema/audio/denon-audio/denon-pma-860-41441/
Any suggestions will be appreciated.
