Denon PMA s10 iii help
Dear AK Friends,
I have a dillema. I used to love this amp till i got a Sansui CA / BA 3000 set and had it recapped. I find the details in the music and the smoothness amazing, especially in the mid an high band. When I use this amp, it sounds flat and lifeless and extremely boomy / flabby on the bass on a A/B comparison.
I feel that this is such a well constructed unit and has a solid feel and look to it. This amp is now 15 years old, Do you think it will hep with a recap on the main power supply as well as driver boards with Elna Silmic ii or Nichicon Audio grade caps? And will it improve the midband and handling of the the bass frequencies?
Please advise if it is worth it or should I just sell it and spend my energy and money on another vintage unit once i get my hands on it.
Thanks in advance for the opinions.
Best Regards
(BTW, the pic is actual and I am now running the amp with Wharfedale Diamond 9.6 towers.)
Integrated Amplifier
<Power amplifier part> Output power
(Both channel drive, CD->SP out) 100W+100W (8 ohms, 20Hz - 20kHz, THD 0.07%)
200W+200W (4 ohms, 1kHz, THD 0.7%) THD 0.01% (Output-power-3dB o'clock, 8 ohms, 1kHz) Output terminal Speaker AorB: 4ohms - 16ohms
Speaker A+B: 8ohm-16ohm
At the time of bi-wiring: 4ohms - 16ohms <Preamplifier part> Input sensitivity/impedance Line: 150mV/47kohm (Source Direct off)
150mV/15kohm (Source Direct on)
Phono MM: 2.5mV/47kohm
Phono MC: 0.2mV/100 ohms Equalizer amplifier output Rec out:150mV RIAA deflection Phono MM: 20Hz-20kHz±0.5dB
Phono MC: 30Hz-20kHz±0.5dB <Synthesis> Frequency response 5Hz-100kHz+0 -3 dB Signal to noise ratio
(A network, an input short circuit) Line:110dB
Phono MM: 91dB (at the time of a 5mV input)
Phono MC: 76dB (at the time of a 0.5mV input) Tone control Bass: ±8dB (100Hz)
Treble: ±8dB (10kHz) Power receptacle switched: Two lines, a total of 120W
unswitched: One line, 240W Power supply voltage AC100V, 50Hz/60Hz Power consumption 300W Dimensions (a base, a knob, a terminal included) Width 434x height 181x depth of 485mm Weight 28kg
