Hi AK
I have a Denon DP 2000 Quartz direct drive turntable that has stopped working. The following thread describes pretty much the same thing but the poster got no replies.
http://audiokarma.org/forums/index.php?threads/denon-dp-2000-start-stop-button-switch.706191/
I will give a little more detail about the issue in the hope that I might tempt someone who knows about these beasts to offer some advice. There isn't much discussion about the TTs in the series. I have followed what limited advice I could find but would appreciate it if someone could offer some assistance.
The problem developed over time. At first the TT would go through speed lags - sometimes they would end by themselves, sometimes I would flick the on-button or 33/45 selector and it appeared that this might have done something to restore operation but I'm not sure. It got worse and eventually it stopped spinning and wouldn't start at all.
I read a thread about a similar model (can't remember which). There wasn't much advice but what there was suggested that it might be fixed by cleaning the contacts on the controls. I did this. At first nothing. Then it started working again. I assumed that the problem was the contacts. The TT played well for a couple of months and then speed lags, stopping for a while (while I tried to work the controls) and then it stopped altogether.
A repeat of the cleaning of the controls made no difference.
I opened it up recently with a view to recapping (in case this might fix it). This thing has a lot of caps and there's no way for someone with my level of understanding to know where to start.
I tested all the switches (a main power switch and two microswitches for the on-button (for rotation) and the 33/45 selector) with a multimeter and they appeared to be working correctly.
The main power switch appears to do what you expect - the strobe comes on/goes off appropriately. However, the on-button doesn't start the platter spinning. Interestingly, toggling it seems to activate the break (pressing the on button changes the state of the platter from spinning freely to being stopped by electrical breaking applied through the motor - this is normal when you stop it spinning). That is the limit of function.
I have a copy of the service manual but it is too big to upload.
Any thoughts on what to do would be appreciated.
Thanks, Jon
Thanks, Jon
