js bach
I'm a Denon fan; I have been since my first two pieces of gear... a DRA-635R receiver and DCD-1500 CD Player. Two pieces which I believe (according to internet writings here and there) were designed by two different design teams that worked for Denon during two different time periods (80’s & 90’s). In addition to the DRA-635 and DCD-1500, I’ve also owned the following Denon pieces over the past 20 years:
Receivers:
DRA-625
DRA-835R
DRA-1025R
DRA-1035R
Integrateds:
PMA-980R
CD Players:
DCD-1700
DCD-1520
DCD-3000
DCD-1290
DCM-444
Power Amps:
POA-2200
POA-8300
Over time, I've noticed a difference in overall sound characteristics between the older Denon gear (80's) and newer Denon gear (90's). Were there in fact two different Denon design teams? Was one team’s “stuff” better sounding than the other? Please keep in mind, everything written here is just my opinion based on my own listening tests. Condition and age of the gear can clearly be a factor in these subjective tests. Please share your own experiences with your favorite Denon gear. Speakers used during most of this timeframe: Mirage M-3si. Prior speakers: Infinity Kappa 8.1, Paradigm Studio Monitor (original), Infinity RS-IIIa’s. I am looking for the right Denon piece to use with my Mirage speakers. Read more below for what’s on the way.
The Receivers…
I seem to notice a distinct difference in the sound characteristics between the “25” and “35” series. I currently have a DRA-625 and DRA-1035R. The 1035 is currently in the shop for a cleaning, and, maybe an adjustment check because it sounds too glaring and harsh as soon as I reach 9 o’clock on the dial. It’s caps may be shot. Now from initial listening between the DRA-1035 and DRA-625, I immediately noticed that the DRA-1035 bettered the DRA-625 in clarity, soundstage and imaging. However, as it stands now, the DRA-625 is still my somewhat “reference” piece (since that’s all I’ve had for a while now). This particular DRA-625 though it not mine. It belongs to one of my friends--and has been on loan for a while now. The only other Denon pieces I did not like due to being overly harsh sounding was the PMA-980R and DCD-3000.
Of all the “25” Series receivers I have owned, the DRA-625 has the best bass response of any I have compared. Thus far, the DRA-1035 is the only one that has come close. The DRA-1025 is lacking by comparison. I’ve read though the DRA-825 has the same bass response as the DRA-625, but is a little cleaner in sound—possibly due to being optical class-A? I never owned a DRA-825. The DRA-835 in comparison reminded me of the 1025, with the 1025 having a slightly warmer sound. The 825 was clean and full (as in midrange), but a little lean in bass, which perhaps caused it to sound somewhat thin. The 1025 though sounded excellent through the volume range and did not sound harsh in any way. Now, given when I have written here, and the time periods from what I could gather, it would seem that the “25” series may have been designed by the 80’s team. Whereas the “35” series gear was possibly designed by the 90’s team? Same would hold true for the PMA-980R, which I believe was a 90’s production. Does any of this seem to hold true? If so, I guess I seem to favor the 80’s Denon sound vs. the 90’s.
Enter PMA….
This weekend I’m scheduled to pick up a PMA-900V from a local seller in my area. I’ve read the PMA-900V is one of Denon’s best pieces? Denon experts and aficionados please chime in. Given that all is electronically sound with this PMA-900V, I’m very curious to see how this will compare in sound to the DRA-625 and DRA-1035. The only other PMA piece I ever owned was a PMA-980R. I couldn’t stand it. Unless there was something terribly wrong with it, it just had a distinctively cold and harsh sound to it.
The CD Players…
The smoothest Denon CD player I owned (hands-down) was the DCD-1500. My second favorite was the DCD-1520. The worst sounding was the DCD-3000. It reminded me of the PMA-980R. The DCD-1290 was ok, but really didn’t have much body to its sound. It had a nice pitch-control feature though. The dcd-1700 was nice, but sounded thin compared to the DCD-1500. The 1500 sounded bold, full, but smooth and non-harsh.
Power Amps…
The POA-2200 was clean and loud, but again sounded thin to me in the bass region. It reminded me of the DRA-835, except a lot louder. The POA-8300 was excellent. Well defined bass, smooth, full mids and clean highs that were not harsh or bright at all. I believe the POA-8300, as well as the POA-8200 and POA-5200 are sleepers in the amp market. You can find them relatively inexpensive (compared to other power amps) and their sound quality is much, much better than most of their equivalents. I believe another very nice sounding piece (though never owned) is the PMA-2000R. In my opinion, the POA-8300 sounded much better than the POA-2200.
Conclusion & Home Theater…
It would seem I used the word “thin” a lot to describe some of the models. I used “thin” to describe the lack of bass response when comparing to other gear. Perhaps too the lesser bass I am referring is also causing the sound to be brighter too? Of all the Denon gear mentioned, the 625 had the best bass response, along with the POA-8300 and DRA-1035. I’m wondering how the PMA-900V will favor? As for design teams, it seems as though the 70’s & 80’s were really nice in terms of sound quality. To me, the 90’s were a little rough at times, with the 00’s and on being a little better? I have to keep in mind too, the 90’s was at the height of the HT craze; so all the manufacturers were putting their design dollars into the HT stuff. I do currently own a Denon AVR-3600 HT receiver. I use it on the flat screen only as the factory speakers are awful. I never considered comparing the 2-channel stereo on the AVR-3600 to the DRA-625 and DRA-1035. I wonder?
Receivers:
DRA-625
DRA-835R
DRA-1025R
DRA-1035R
Integrateds:
PMA-980R
CD Players:
DCD-1700
DCD-1520
DCD-3000
DCD-1290
DCM-444
Power Amps:
POA-2200
POA-8300
The Receivers…
Enter PMA….
The CD Players…
Power Amps…
